Car adapt after ECU Tune?
Question for you guys. I just bought a used tuned ecu. The guy i bought it from said it was tuned by viva performance with rica program. I installed it tonight and took it for a drive. Couldnt honestly tell a difference. I only drove it maybe 3 miles total but felt stock. I even turned my mbc all the way down and didnt boost over 12. Do i need to reset the car after installing this or did i get a dud. He said it takes a little while for the car to adapt to the ECU. What do you guys say. Im ready to file a paypal claim on this guy.
I'd file the claim. Should have felt a difference immediately.
take out your MBC... if you dont boost past stock in 4th gear on the highway get your money back!
Yeah i am planning on removing the mbc and seeing how it drives. I know one thing, it def still has the torque limiter in 1st and 2nd. That was my first sign that its not rica or tuned or at least i dont think it is.
doesn't matter what ecu you have in it, if you have a mbc in, it's going to boost to whatever that's set at.
And the tune might be set for 12 psi. Stage 1 tunes are usually set around there. I'm currently looking for a stage 3 tune and from what I've read, RICA tunes are tuned pretty conservatively. |
well he told me it was a 18 psi tune. All i know is i couldnt tell a difference in how it drove compared to stock ecu. I turned MBC up didnt make a difference.
Originally Posted by matt01
(Post 256861)
Originally Posted by boostnm3
(Post 256908)
I would never even consider running a MBC or tune of any sort without a boost gauge. Thats really the best (and only) way to tell quantatively what your turbo is actually doing.
Originally Posted by ibified
(Post 256937)
(Post 256937)
I have a boost gauge installed. Thats why i said i never boost past 12 psi max. When i took the MBC out and ran the factory one, it would only boost to around 5 or 6 psi so i highly doubt this is a rica ecu. Like i said, it didnt feel like anything special or any tune. Felt stock. As far as boost before, i had turned the MBC down to like 3 psi for fuel economy to see how much it helped or didnt help. Before that i was running 10 psi on my stock ecu. I eliminated the MBC so i know thats not the problem. Maybe my wastegate is out of adjustment but the MBC should take care of that. |
Hmmmm, 12psi max on a MBC....If I wanted I could destroy my engine with a MBC. Sounds like you have something else wrong.
i dont know, i know a month ago or so i turned the mbc up with stock ecu but kept hitting fuel cutoff so turned it back down.
(Post 256974)
(Post 256992)
Thats good, now try it again with this ECU. |
Originally Posted by boxpin
(Post 257133)
i did and could boost past 11-12 psi so something is up with this ecu. i talked to the guy to give me a refund. he said he thought his tranny was going out but its obvious his tranny is fine and this ecu is his problem |
