CBV Complete Failure?
before i was peaking at 9psi even with a MBC..
my volvo friend told me to disconnect i the red line ( the one that controlles the wastegate, maybe its the yellow then)
and then you should get max boost, so i tried it ( to test if it was the CBV or other) and i was ripping it to test and i peaked at 9psi, then i lost all power, and i now peak at 4 psi, once i hit 4, it withers down to nothing.
whats happening?
whats happening?
OMG !!! Thats the worst advice anyone can ever give you !! The turbo will just keep making boost untill the engine blows with the vac. line to the wastegate disconnected.
I'd say the CBV is the least of your worries now.You will prob. be looking @ getting a new engine now.
it never boosted more than 9psi.. also i have stock ecu, so the ecu would have cut at 15psi
similar story posted here, same thing i tried also: http://www.matthewsvolvosite.com/for...28026&p=124159
starting to think that i just need to reset my ecu.
trust me resettign your ECU does nothing look at your cbv i'm doign that tommorow!
i'm in the same boat
5-6 psi without MBC
5-6 psi WITH MBC
10 psi with the WG line disconnected
and btw disconnecting you WG line does noting like matt01 your saying the ECU would hit fuel cut at 15 so its not even that bad
however i cant get higher boost not matter wat i try so i'm lookign at the CBV tommorow and gunna see wats up!
5-6 psi without MBC
5-6 psi WITH MBC
ya, im sure i didnt harm my engine, however im sure i did harm my CBV further.
theres no way i hurt anything, i never hit more than 10 (because something is broken) and fuel cut is at 15 if anything happens.
im sure it has to do with an intercooler hose or a failed CBV.
im going to pick up and ipd CBV tomorow, im lucky enough that a dealer near me has 1 in stock. 90$
I have only read of 1 failure on Volvospeed, nor have I read a post from Lucky or IPD stating they have recalled their HD CBV diaphragm. If you can post a link to their announcement would be helpful.
Just wondered where you heard or read their announcement. Since A8 apeks was the only post I had seen for a defective unit perhaps others posted and I missed them. They are mass produced so problems can occur. Similar happened when I purchased their TCV, it was defective, but they promptly provided a replacement.
I had the same thing happen.Turned out to be my cat. was clogged.
Put the OBX on and no more boost problems !!
Well lets see.I checked the CBV,it was good.Still wouldnt make full boost.Before that I had checked all vac. lines and int. hoses and piping.
Did full tune up incl. fuel filter etc. Put on MSD coil,newer injectors and fuel press. reg. Still wouldnt make full boost.
Cleaned the mass air,still wouldnt make full boost.
Got rid of the stock exh. and put my OBX catless turboback on and whatdaya know !! It made full boost !! So I'd say thats a pretty clear sign the cat. was badly clogged.
