Cheap scanner for 96 850 T5
I just bought a T5 with 80 000 miles. I am thinking of buying a scanner. Can someone recommend one? I don't need super functionality, just standard code reading.
RE: Cheap scanner for 96 850 T5
I got one at Auto Zone for around $70. Does what I want it to do.
Can the cheap ones reset codes?
I unhooked the seat tensioner while reparing it and the SRS light is on. Can the cheap OBDII units reset this code?
Thanks, JM |
RE: Can the cheap ones reset codes?
Nope. Won't do the Service light either. I think the SRS light is dealer only.
If you spend between $2,500 and $3,500 you can get one to clear the SRS codes.
In that case, I'll take two.
Can I borrow one?
ME TOO????
I don't even have one. A little to rich for my BLOOD. |
According to Alex Peper from Car Code, his software will reset the SRS indicator...
================================================== ======= Yes, this will use the ISO protocol. Model ISO $122 USD will need a laptop or PC with a rs232 male serial com port. If USB port will need model ISO iTran $132 and a universal USB to serial adpater $28 Alex Peper Car Code www.obd-2.com ----- Original Message ----- From: Axel Mammes To: support@obd-2.com Sent: Saturday, February 25, 2006 4:47 AM Subject: 96 Volvo 850 Can your product reset the SRS maintenance indicator on my car? Regards |
