cleaning pcv system?
Is there any way to clean or flush out the pcv system? Anyone ever tried? Just wondering if it's possible rather than wait to get the parts ordered in.
Thanks |
im just about to do mine today though i just got my new oil trap yesterday i tried running cleaner through the lines and i had no luck
youl probably just want to order a new one from FCP GROTON THEY ARE RELATIVELY CHEAP AND THEY COME WITH THE NEW INTAKE GASKET WHICH YOU WILL NEED after you take the intake manifold off - dont be cheap when reassembling your car the old maifold gasket will leak - trust me - been there done that
good to know guys thanks
Just replace the system. Cleaning it will not work.
Chances are all of your hoses will crumble anyways when you try to remove them.
You can clean. but you will be doing triple the work and like Gil said, some of your hoses might Disintegrate. I would just replace. The price is cheap to buy all the new stuff!
When you do the work, regardless you'll want to buy a new fuel line if you're replacing your PCV system and you'll want to buy extra vacuum tubing for most everything attached to your turbo control valve.
Originally Posted by RockVegas
(Post 206616)
I found this procedure:
http://lakesidedp.com/uploadpics/pcv/ Looks like a PITA, but I need to do it since I see oil puddling on top of the head near the spark plugs. |
Same write up I used. The first time you do it it will take you probably a weekend, after you do it once it's easy, i can do the PCV in about an hour now.
TIP: You do not need to remove bottom row of bolts on intake manifold, just loosen them. |
Gilber, if you look at that procedure above, I had to cut through hose (step 6) C. That joker was practically welded to the metal.
Yeah, it's a pain for sure. It probably took me 6 hours to fumble my way through and replace extra hoses, but in the end the job was done and I didn't have to pay a mechanic. |
Originally Posted by radio16
(Post 206402)
It's not a PCV valve, it's an entire system including an oil trap. More than likely the whole system is clogged and replacing one part won't fix the problem. When I replaced mine the trap was clogged, the lines were cracking and clogged.
