Code 122
Old Dec 5, 2007 | 04:14 PM
psi notch's Avatar
Default Code 122
I'm looking at purchasing a 94 850 turbo... but it has an engine light on for a code 122.... now the owner said something about it being in b2???? and that it had to do w/the cruise control... can anybody elaborate on this.. I'm a volvo NEWB.
Old Dec 5, 2007 | 04:51 PM
billofdurham's Avatar
Default RE: Code 122
On the '94 850 there are two diagnostic boxes in the engine compartment - A & B.Socket B2 is used to check for fault codes in the cruise system.
Code 1-2-2 is Speed below minimum/no signal.
When checking for fault codes on B2 it should be done after a road test which must exceed 22mph otherwise code 1-2-2 will always be stored. The test must be done before the engine is switched off otherwise 1-2-2 will be stored and the road test will have to be repeated.
Ask the owner if he did the diagnostic test correctly. 1-2-2 is really nothing to worry about.
Old Dec 5, 2007 | 06:40 PM
psi notch's Avatar
The thing that bothers me is the check engine light being on b/c of it... so how would I go about fixing it.. b/c he also says the cruise control only works intermitently sp*.
Old Dec 5, 2007 | 07:59 PM
psi notch's Avatar
Should this code set a check engine light?
Old Dec 6, 2007 | 12:59 PM
The code 1-2-2 is erased as soon as the ignition is turned off. Have the owner, or yourself, check for fuel system codes using A2 and ignition system codes using A6. Something other than the cruise control is setting the CEL.
Old Dec 6, 2007 | 05:34 PM
JimKW's Avatar
Cruise control problem is probably caused by a vacuum leak. There is a hose under the battery that has a tendency to get broke. I would leave the CEL light on and tell him the cruise control unit is shot and is expensive to fix. Then low ball him on the price of the car. I love to pull crap like that when buying a car.
Old Dec 6, 2007 | 06:50 PM
Code 122 for the fuel system is Intake air temp sensor missing or faulty.
Might be a bad Mass Flow sensor.
Old Sep 30, 2016 | 04:57 PM
pkc303's Avatar
Default Code in B2
The code refers to no speed signal. Your speed sensor is bad, or the connector is bad. Have the same problem.
ClayW
May 24, 2011 08:46 AM
gtbassett
Jan 25, 2011 01:37 PM
neufie
Jul 20, 2009 04:50 PM
afi76
Aug 14, 2007 12:56 PM
ovlov
Oct 21, 2005 09:56 AM
