-   Volvo 850 (https://volvoforums.com/forum/volvo-850-16/)
-   -   Code 122 (https://volvoforums.com/forum/volvo-850-16/code-122-a-15690/)
psi notch Dec 5, 2007 04:14 PM
Code 122
I'm looking at purchasing a 94 850 turbo... but it has an engine light on for a code 122.... now the owner said something about it being in b2???? and that it had to do w/the cruise control... can anybody elaborate on this.. I'm a volvo NEWB.
billofdurham Dec 5, 2007 04:51 PM
RE: Code 122
On the '94 850 there are two diagnostic boxes in the engine compartment - A & B.Socket B2 is used to check for fault codes in the cruise system.
Code 1-2-2 is Speed below minimum/no signal.
When checking for fault codes on B2 it should be done after a road test which must exceed 22mph otherwise code 1-2-2 will always be stored. The test must be done before the engine is switched off otherwise 1-2-2 will be stored and the road test will have to be repeated.
Ask the owner if he did the diagnostic test correctly. 1-2-2 is really nothing to worry about.
psi notch Dec 5, 2007 06:40 PM
RE: Code 122
The thing that bothers me is the check engine light being on b/c of it... so how would I go about fixing it.. b/c he also says the cruise control only works intermitently sp*.
psi notch Dec 5, 2007 07:59 PM
RE: Code 122
Should this code set a check engine light?
billofdurham Dec 6, 2007 12:59 PM
RE: Code 122
The code 1-2-2 is erased as soon as the ignition is turned off. Have the owner, or yourself, check for fuel system codes using A2 and ignition system codes using A6. Something other than the cruise control is setting the CEL.
JimKW Dec 6, 2007 05:34 PM
RE: Code 122
Cruise control problem is probably caused by a vacuum leak. There is a hose under the battery that has a tendency to get broke. I would leave the CEL light on and tell him the cruise control unit is shot and is expensive to fix. Then low ball him on the price of the car. I love to pull crap like that when buying a car.
tech Dec 6, 2007 06:50 PM
RE: Code 122
Code 122 for the fuel system is Intake air temp sensor missing or faulty.
Might be a bad Mass Flow sensor.
pkc303 Sep 30, 2016 04:57 PM
Code in B2
The code refers to no speed signal. Your speed sensor is bad, or the connector is bad. Have the same problem.
