Code help
All,
I decided to finally check all the codes that may be stored in my sons 95 850 Turbo. Car runs great, but it had several codes stored. It had a 114 in A1, a 211, 212, 213, and 214 in A3, a 113, 122, and 132 in A7, and a 122 in B2. Anyway, I cleared them all and drove the car for a few miles. Brought it home and checked them again. All codes stayed clear, except the 122 in B2 Can anyone tell me what that code means, as I cannot find it anywhere? Also, I get no response from the A6 socket on the car. There is a metal contact and wire in the diagnostic socket, but no matter what, I get no response when I push and hold the button for a second to retrieve any code. THanks for any answers, Glenn |
RE: Code help
122 in B2 (cruise control) means you did not reach 35 MPH - no code, really.
A6 is ignition, but you have to hold the button for MORE then 1 second, and less then 3. Good luck. If still not working, try pulling Diagnostic module and check the terminal under it-could be bad connection/soldering |
RE: Code help
I'll give that a try regarding the A6. Thanks for deciphering the 122 code for me.
Glenn |
