Did the headliner in Suede
I read over this write up, http://www.matthewsvolvosite.com/for...hp?f=1&t=26848. It documents the removal and install steps well.
After removing the headliner I used a push broom to wipe off any foam that was left. For material I used Suede Cloth, traditional Suede leather is too heavy to use on the headliner board. I attached it directly to the headliner using Loctite headliner adhesive #37312. I did not install any foam behind the suede as its not needed.
I painted the trim with Black plastic paint but I dont like how it came out so Im going to try Charcoal Grey Trim Dye made by VHT, http://www.amazon.com/VHT-SP954-Viny.../dp/B000CPCRQI.
Im going to cover the visors in suede toady so I should be able to get some pictures of those up soon.
I used spry paint for plastic. Not recommended! I should have and will be using a dye.
I have a set of light grey handles and map light from an s70 that I will be swapping in once I dye them charcoal. I also found a set of 960 sun visors in black that I will be using as well.
Black trim that fits an 850 was never available. Only tan and light grey.
The suede looks lighter in the pictures because of the flash. Its actually black suede and in person is a lot darker. The handles are still too dark and Im thinking the charcoal dye will look better.
You are correct about the visors. Its a pain to wrap around the edges. I used glue and folded the edge under to give it a smooth transition but its still too obvious for my taste. If the black visors dont do the trick I will have them wrapped when I get the steering wheel and shift **** redone by a local shop. They are backed up for a few months so I have time to kill and just experimenting with what looks best. The local recycle yard had a couple 850's so I pulled several handles and trim items to play with.
Plan to pick up some material for the door panels tomorrow.
OMG i could hug you right now i have always wanted to do this to my t5r this thread takes all the guess work out. I love the way it turned out man great job, and u should check out some local paint shops and auto parts retailers because here in Frederick MD there is a place that will mix up a spray can of interior paint matched to volvos factory charcoal color, best of luck man
johnwartr
02-21-2014 04:12 PM
96960Chris
11-05-2010 03:50 AM
winner3
07-20-2009 04:35 AM
ExtremeODD
02-15-2008 05:59 PM
