DIY: Volvo 850 T5 Camshaft Sensor Testing & Replacement (Video Tutorials)
Video tutorial on how to test the camshaft sensor of a Volvo 850 equipped with a 5 cylinder. This tutorial was done on a 1996 model. If your vehicle has no spark, hard starts, or is running rough, this could possible be the culprit of the problem. Procedure: -the plug for the camshaft sensor is located directly under the distributor held in my a metal bracket -unplug the harness by depressing the metal retaining clip on the plug and pull straight back -once the plug is disconnected, using a multimeter you're able to test the pins for continuity and voltage readings -the number of the pin is printed on the rubber portion of the plug in very small lettering -determine what your vehicles battery voltage is by testing the vehicle's battery -test Pin 1 (ground) for continuity to the ground on the battery -test Pin 2, with the key in position 2, should read approximately 5V -test Pin 3, with the key in position 2, should read approximately battery voltage -turning the key off now, using sewing needles, insert the needles in the backside of the connector on the ecu end to Pin 1 and Pin 2 -ensure they are connected by testing the continuity -connect the plug back to the camshaft position sensor -an analog multimeter is required for this job because the voltage pulse will not read accurately on a digital meter -touching the test probes on the exposed needle ends, have someone turn the engine over and watch for a pulsating voltage -the voltage should read approximately 5V, similar to what Pin 2 reading was earlier on in the tests -if there is no faults with the previous voltage tests, but there is a weak or no signal voltage, the camshaft sensor is faulty -having the probes touching each of the exposed needle ends Camshaft Sensor Replacement Video tutorial on how to replace the camshaft sensor of a Volvo 850 equipped with a 5 cylinder. This tutorial was done on a 1996 model. If your vehicle has no spark, hard starts, or is running rough, this could possible be the culprit of the problem. Testing for a faulty camshaft sensor: Procedure: -unclip harness with is located directly under the distributor caps, depress steel clip and pull plug straight out -camshaft sensor is located on the distributor side of the motor, to the rear of the valve cover under the top motor mount -remove the vacuum lines in the bracket which comes off when the lower bolt is removed for the camshaft position sensor -remove the 2 torque bolts which are T-40 -the sensor should pull straight out -reinstall new sensor in reverse |
Camshaft position senser S90
Dear All,
I need a 2nd opinion on my S90 1997 which has indicator on dashbox and garage mechanic diagnostic message on screen shows "CPM 314 Permanent/ Faulty Signal Faulty; Camshaft position senser signal absent or EVAP system faulty." Other than replacing a new sensor as immediately mentioned without further check by mechanic, wonder if there is any other alternative before paying for the new Sensor?? Thanks Stewart |
Try a used sensor...
