Does anyone know how to test remotes???
I have two remotes that do not work with my car. I tried to program them but still no action.
So I took them to the local stealer and local Auto Zone and they claim they don't work. However, they also claim that my WORKING remote does not work :confused: If anyone knows another way for me to test these or program them in my '95 850, please let me know. |
Is the FCC number on the back of the remotes the same for the working and non working ones ??
Yep!!!
Our autozone has a tester by the counter that you put your remote up to it and it has a light that lights if its broadcasting.
Which ones are yours the ones that the bottons are horizontal or the vertical ones?
So i will need that for my car. Instead of the other one or boths can be set in the 850?
Originally Posted by boxpin
(Post 306712)
They work with factory remotes but I think some of the aftermarket add on units like remote starters and some car alarms work on channels that the tester will not pick up. |
Originally Posted by gabyman97596
(Post 306732)
Does your car have the light that comes on the dash after you lock the door? |
Yes it does has the light and it flashes. I bought the rectangular one it was cheap on ebay
I like pictures
1 Attachment(s)
Originally Posted by rspi
(Post 306818)
You need to pull your glove box and see what the TRANSMITTER code you have. The alarm box is on the right side behind the glovebox. It has a green plug going into it and a sticker with the code.
Does your car have the light that comes on the dash after you lock the door? The receiver is the little black box on the right side of the glove box well. Once you get the glove box out you can see it and pull that number off of it. |
