easiest point to hook a boost guage?
Where is the closest?
where is the easiest? or the best location or route...to hook up A boost guage? Ive had it!!!!!!! I wannna know EXACTLY WHATS GOING ON. also.........a route for an oil guage i need too. |
RE: easiest point to hook a boost guage?
you can use a new line all the wat to the lil vacuum tree on the intake and rout it that way or there are oodles of other spots you can 'tee' in to
3/16 ID fuel line fits great over the line for the factory boost gauge line right up front by the battery you could use some of that to splice in to it -Mike |
What Mikey said...
To penetrate the firewall, there is a short conduit above the driver's side footrest. It's capped off at each side; look for a rubber cap with three nipples on each side. |
thanks guys
thats what i wanted to know. but was hoping maybe there was a vacume line right on the dash somewhere. is there an oil sender anywhere? i can hood the oil guage to? the one i have is not electric |
Why noy use the line at the Dash if you look under the dash you can't miss it.(from the stock guage)
The oil sender location is in the pic. [IMG]local://upfiles/853/6AC10B71419D477FA6CBBC87D689113D.jpg[/IMG] |
| All times are GMT -5. The time now is 01:42 AM. |
