ECC 2 lights blinking, have codes..interpretation?
Old Dec 16, 2012 | 03:48 PM
ded137t5r's Avatar
Default ECC 2 lights blinking, have codes..interpretation?
I have the ecc lights blinking and so I pulled the codes and the are as follows:
135
325
414
417......interpretations of whats wrong and how to fix it?
My ac hasn't worked and still doesn't. I flip the ac switch and there is no click of the clutch on the compressor or and cycling.
Would these codes stop the ac compressor from turning on?
Old Dec 16, 2012 | 04:24 PM
What year 850 do you have ??
http://www.matthewsvolvosite.com/read-codes-volvo-850
Old Dec 16, 2012 | 04:50 PM
Originally Posted by ded137t5r
135
325
414
417
Has the AC ever worked ??
Clear the codes until it flashes a 1-1-1 back at you.
For the #414 take a can of compressed air and blow out the temperature sensor fans. The sensor fans are located directly above (behind) the grab bars above the doors. Remove the grab bars and the sensor grills, use some compressed air to blow all of the lint out of them and give them a shot of oil. They will normally come back to life.
135 No signal from engine coolant temperature sensor
Possible cause the sensor failed, the connector is loose and or dirty or a lead may have been pinched or cut.
325 Recirculation damper motor active too long
414 Driver’s side interior temperature sensor inlet fan seized
417 Passenger’s side interior temperature inlet fan seized
Photo is the coolant temp sensor and the coolant temp sensor installed in the thermostat housing just under the upper hose.
Attached Thumbnails ECC 2 lights blinking, have codes..interpretation?-coolant-temperatur-sensor-new.jpg   ECC 2 lights blinking, have codes..interpretation?-coolant-temp-sensor-2-.jpg   ECC 2 lights blinking, have codes..interpretation?-heat-ac-interior-temp-sensors.jpg   ECC 2 lights blinking, have codes..interpretation?-heat-ac-interior-temp-sensor-dirty.jpg
Old Dec 16, 2012 | 08:17 PM
JPN's Avatar
JPN
Good luck & Happy Holidays.
JPN
Attached Thumbnails ECC 2 lights blinking, have codes..interpretation?-850-acc-oat-location.jpg   ECC 2 lights blinking, have codes..interpretation?-850-ecc-interior-temp-sensor-2-.jpg   ECC 2 lights blinking, have codes..interpretation?-850-ac-damper-motor.jpg
Old Dec 17, 2012 | 01:16 PM
ded137t5r's Avatar
I have a 1995 with obd2 and the diagnostic unit by washer fluid resivore.
Old Dec 17, 2012 | 01:29 PM
ded137t5r's Avatar
Yes it worked great about 2 years a go and all the sudden stopped working. Every time I flip the ac switch I hear no engagement of the compressor clutch. No cycling either.
I'm going to work on those two side sensors and I think the coolant sensor had coolant spilled on it durring my recent radiator swap. But if the sensor is bad, why is my dash displaying a temp and it gradually rises to half way like normal in about 3 to 4 min from cold.
What do I do about the recirculating ac damper motor being open too long? Is it easily acess able?
Old Dec 17, 2012 | 01:31 PM
ded137t5r's Avatar
JPN
Thanks for all the diagrams.
Happy holidays!
Old Dec 17, 2012 | 05:07 PM
Well, I'd say you need to do some of the leg work and google your codes and them google different key words from the trouble codes. Matthews Volvo site and Volvospeed are two good resources to search.
If it's the motor that is across from the blower motor that shaft is know to split. The motors rotational output is with a hollow shaft that a metal shaft from the blend door slips into. It gets brittle with age and or something causes the door to bind and the plastic splits allowing the shaft to rotate freely inside it. The motor is working great but it's not moving the door. Maybe ??
Attached Thumbnails ECC 2 lights blinking, have codes..interpretation?-heat-ac-damper-motor-broken.jpg   ECC 2 lights blinking, have codes..interpretation?-heat-ac-disassembled-mode-motor-lubed.jpg
Old Dec 17, 2012 | 05:12 PM
If that shaft is split ,,, this is one way to fix that.
http://www.matthewsvolvosite.com/for...hp?f=1&t=18514
rcvolvo
Jan 25, 2014 01:34 PM
pablogiovani
Oct 22, 2011 05:44 PM
Luke93 850
Aug 3, 2011 07:22 AM
deathbots
Jul 22, 2007 05:36 PM
cava
Dec 19, 2006 03:06 AM
