ECC blinking lights.
Old 02-28-2018, 02:17 PM
rcvolvo's Avatar
Default ECC blinking lights.
How do I hook up my OBDII to check codes on my ECC ? 96 Volvo GLT...Thanks.
Old 03-01-2018, 07:09 PM
most OBDII readers only read powertrain/emissions codes not the special chassis codes.
FYI, check out this vid.
Old 03-02-2018, 10:38 AM
firebirdparts's Avatar
Well, that's great! I wonder if that works on some years of the V70.
Old 10-18-2018, 10:28 PM
spannbauer's Avatar
I tried this on my 96 850 turbo and it didn't work at all. At first I didn't have an LED bulb so I used an incandesent bulb, everything seemed to work just as the clip said but no codes or blips of light to read appeared. Then I ordered a 12v led and tried it, but it didn't even light up before the ignition was on, and still no codes were able to be read. At this point, I don't know.
Old 10-19-2018, 10:08 PM
gdog's Avatar
Sounds like you either mis-wired it or the led is connected backwards. Check it again; it should work.
Old 10-23-2018, 10:53 AM
spannbauer's Avatar
Spot on! Hat's off! Yes after checking, with attention to detail, I did have the led light wired backwards. Once corrected I was able to receive codes to see my direction. Both my interior temp sensors need work or replacement. I see these are discontinued and I haven't been able to locate any anywhere, it there a fix for these? What are my options here, if any? Thanks.
Old 10-23-2018, 07:40 PM
gdog's Avatar
Yeah I wish I knew where they were available. I've got a 417 DTC as we speak. I could have sworn these were recently available (volvo p/n 9134822 or 9144337) on fcp and other sites. I even emailed fcp a few days ago, but they said nope, NLA. Guess I'll try to scrounge a working one from pic n pull, but that's an unreliable fix at best. I've tried the "cleaning and lubing" thing, but from my experience, it 's only lasts a week or so.
Amanaland
08-11-2015 11:07 AM
97GLT
07-04-2008 05:59 PM
panbuk
04-12-2008 08:09 AM
Capo Cam
03-15-2008 04:59 PM
Musicjunkie2k
10-22-2005 07:27 PM
Quick Reply: ECC blinking lights.
