ECC blinking lights.
I tried this on my 96 850 turbo and it didn't work at all. At first I didn't have an LED bulb so I used an incandesent bulb, everything seemed to work just as the clip said but no codes or blips of light to read appeared. Then I ordered a 12v led and tried it, but it didn't even light up before the ignition was on, and still no codes were able to be read. At this point, I don't know.
Spot on! Hat's off! Yes after checking, with attention to detail, I did have the led light wired backwards. Once corrected I was able to receive codes to see my direction. Both my interior temp sensors need work or replacement. I see these are discontinued and I haven't been able to locate any anywhere, it there a fix for these? What are my options here, if any? Thanks.
