ECU identify, Boost controller setup, a/f
It is the oil trap system (PCV system). Here is a good write up on it: http://www.lakesidedp.com/uploadpics/pcv/.
You can try cleaning it or if it is messed up you can get a kit from http://www.fcpgroton.com/.
You will have to talk with tech. He knows more about this than anyone here.
What you could check, IS the intake/ intercooler hose, and clean them. on the intake hose, there will be a little nipple, that might be clogged with oil.
did you order the complete kit? if so that is a great price. i bought mine from fcp for $150.make sure it comes with a new intake manifold gasket.i think its also important to get a new oil cap gasket.mine leaks pretty bad from all that built up pressure.hopefully that will work and i dont need a new cap.i also got a TB gasket...i want to clean everything i can while down there.
TECH,anything else i should look for or replace while im in there.im doing it on saturday if it doesnt storm like it has been this whole week
Is this everything I will need... It seems cheap compared to other sites
http://www.ipdusa.com/version.asp?st...849&V_ID=12576
This kit here (http://www.fcpgroton.com/product-exe...category_id/63) seems to have more parts and is almost double the price.
