Engine bolt sizes
Old Apr 24, 2020 | 12:52 PM
highlander00's Avatar
Default Engine bolt sizes
what is the size of bolts which go into the back of the engine on this 97 850 engine? I'm putting it on an engine stand and can't get to the hardware store to check sizes. and which holes should I use for the engine stand?
Old Apr 24, 2020 | 05:30 PM
do you have the original bolts? if so see if there's a stamping on the head to show the size ie M40 or something like that. Otherwise measure the bolts diameter and thread count (think metric so if you measure 10 per inch, convert to centimeters) - then you can consult a metric ISO thread table like http://www.dinstock.com/useruploads/...en_iso4014.pdf
Or go to a volvo dealer parts store and have them send you a few bolts
https://www.volvopartswebstore.com/p...24/982819.html
As to where to bolt up to, I'd use the threaded holes in the outer casting but not the ones with the guides...
andybbrown
Mar 31, 2015 08:20 PM
andybbrown
Mar 31, 2015 08:18 PM
andybbrown
Mar 31, 2015 08:15 PM
Counselor828
Aug 22, 2011 12:19 PM
Ghost Brick
Oct 5, 2010 10:43 PM
