Flashing Battery Warning Light
Gidday,
I have a 96 850 which has been displaying odd behaviour. It started with the ABS light coming on suddenly and then going off a few minutes later. This happened twice. Then a few days later as I was driving ALL the warning lights came on. Now finally when I turn the car off the Battery warning light flashes at me. Can anyone tell me what this may indicate? cheers David |
RE: Flashing Battery Warning Light
With the car running wiggle the ignition switch a little bit and see if the lights come on.The electrical part of the switch goes bad and gives signs like that.kinda try to turn it easy foward and back and see if the lights come on while the car is still running.If so then the switch needs to be replaced.
