funky steering
For thoes of you who have read my older postes you know about laundry list of issues i've had with my car.Last night i just got done replacing both control arms and tensioner for the serpentine belt. It took me close to an hour to get my car running, it would turn and just barely fire, after a while it started to fire more and finally enough to keep itslef running. I've had engine issues for a couple months and the check engine light finally came on last nite so i can run the error codes and see what it says. I need hlep brainstorming what is going on w/ my steering. i'll have the wheel straight and the car goes straight, then all of the sudden, the wheel is about 25-30 degrees to the left and the car is still going straight. and then the wheel will go straight again. I'm sure I missed something when i put my suspension back to gether, any ideas what i may have missed?
RE: funky steering
I forgot to mention that both sides of my front axle have been replace as well.
RE: funky steering
Did you check for play in the front end after assembling everything?
It might be something internally in the rack. |
RE: funky steering
Oh, glorious day... after almost two months of diagnosing one problem after the other, i have my car back on the road. She runs great, handles better than she ever has since i bought her, and no more strange noises coming from my front suspension. i have only had two small problems since i got her back from the mechanic last night: 1. I had to let her idle for almost an hour to heat up and melt the inch or so of ice on all the glass 2. driver side lock was frozen this morning. I'm just happy to be driving my own car again, it feels great.
RE: funky steering
Glad it is back and running good now.
RE: funky steering
Ditto, Glad it is back on the road. What casued the funky steering?
RE: funky steering
OK, I made it out of the woods for a couple days. yesterday, sometimes i had power steering, sometimes i didn't. at first it seemed like my belt would squeak when the steering wasn't working right, but after the belt stopped squeaking it still tuned hard. i'm pretty sure it's my steering pump, since the rack only has about 100 miles onit. i checked the resivoir, it's not low so there is no leak. hopefully i can repair the pump instead of replacing it. now it's time to see if fixing lawnmowers at a country club has finally done me some good.
RE: funky steering
Is it possible that you have air in the system from replacing the rack??
RE: funky steering
it's possible, but in my experience w/ hydraulic systems (i'll admit is almost all with linear piston systems and not with the circular system that my steering uses) whenever there is an air pocket it shows itself right away. my steering worked perfect for a little over two days before this problem arose.anyone, if i am wrong, please let me know. the steering is starting to behave more like it should, but it's not quite all there.
RE: funky steering
Usually with these systems after a small ride around the block all the air is out.
RE: funky steering
i've heard that the steering system on my car doesn't use power steering fluid, it in fact used automatic transmisison fluid. is that true? if so, i beleive the machanic i took it to used power steering fluid when they replaced the rack. how would i go about draining that and replacing it with the correct fluid?
RE: funky steering
Yes it is supposed to have ATF in there. You should be able to pull the return hose and crank the car over and pump the old out and pour in new till it is full with the new.
RE: funky steering
could the wrong fluid in there be causing it to act the way it has? or am i still looking at replacing/fixing the pump?
RE: funky steering
I have seen alot of people run power steering fluid in them with no problems but you never know.
RE: funky steering
Wrong fluid could cause the problem you are experiencing. At the very least I would give it a shot and change out the old fluid. What have you got to lose?
RE: funky steering
OK a couple days ago i thought my pump has siezed up and broke the belt. got the car to my folks house running off the battery. finally got a chance to pop the hood today and take a look. the pump has fallen apart. i got the pump out of the monting bracket and ordered a new one. OMG i hope at least done fixing this thing for a while. at least long enough for me to give my wife's car the tune up i't been needing for about 6 months now. on the plus side, i'm rapidly running out of things to fix on my car, it won't be long and everything will be a new part.
RE: funky steering
In case if you wish to do a major tune up on your 850:
https://volvoforums.com/m_48928/tm.htm Happy New Year, JPN |
