Good Deal ??
I just bought a 1995 850 Turbo Silver, it has 103K on it for $1,600
The only problems so far that i have noticed is that it leaks oil seems like by the oil pan, the odometer is stuck, and i believe i need to replace the whole pvc system because when the car is running and you take out the dip stick it puffs out air, but everything else works fine, the turbo spools up good, all eletronics are fine, brand new Fuzion VRi tires, no rust, body is in great shape, and this is my first Volvo, I owned many turbo cars, is there something else that i need to check that i dont know ???? |
Maybe, have you named her yet???
So you picked up Quick Silver... Sounds like a good enough deal. Get those oil leaks fixed, then work on the vaccum problems and the rest should be at your own pace.
Any car that runs with a good body should be a good deal. |
Pretty good deal.
You have a bit of work ahead of you but you got a good deal
