Had some codes run
After getting the PNP done, I went in today to get codes run and cleared.
What came up baffled me to an extent. Codes that came up were: P1308 ( Manufacturer control Ignition System/Misfire) And TWICE code P0133 came up for CKT Slow response bank 1 sensor) The second one I believe is one of the O2 sensors. What is the P1308 code? And why isn't the CEL on? |
What the HELL is an accelerator sensor?
Where is that located? Is it hard to fix? This seems like such a rare problem. I think I'll jank one from a salvage yard before trying to hunt one down. Same on the Turbo and N/A? |
That is all I could find. Wait for tech and experts.
http://www.justanswer.com/questions/...e-98-volvo-s70 |
On the 94 it might be the sensor on the throttle cable.
The newer cars there is a sensor mounted on the subframe under the passenger side front by the dryer. |
I have read about something under the cowl grilles. I see some sort of sensor underneath mine.
But, the sensor is actually on the throttle cable? |
check post by Ozark Lee on VS http://volvospeed.com/vs_forum/index...07-code-p1308/
Hey another sensor I have seen 1000 times but could never find much info on it! LOL
But in the cable sensor it is part of the cable just before the firewall. |
Damn!
Where can I get a replacement for cheap? And in that post the guy still talks about under the cowl... This one beats me |
It will be next to where the pollen filter is.
LOL where is that at?
Under the Cowl panel on the passenger side.
