Hard starting when zero or below
Old Jan 22, 2008 | 03:06 PM
rlseverance's Avatar
Default Hard starting when zero or below
I have a 1995 850 turbo wagon. When it is around zero outside the car is hard to start, and when it does, it idles very roughly, will not accept any throttle, and if I look under the hood the upper intercooler hose is colapsed. After several minutes the car starts accepting throttle and builds revs, after about 10 minutes it drives normally.
Old Jan 23, 2008 | 12:45 AM
zmontgomery's Avatar
Default RE: Hard starting when zero or below
I would replace the hose and see if that helps. I would think that it would be starved for air with a collapsed hose, which would in turn result in an incorrect air/fuel mixture, and cause the rough idle.
Old Jan 23, 2008 | 08:41 AM
Psaboic's Avatar
Yep, I would also replace the hose. Even if it doesn't fix the issue, it cannot hurt. Do you have a check enging light or any codes??
Old Jan 23, 2008 | 03:19 PM
Two things:
1. the hose is not collapsed normally, if the car is not running, it is not collapsed. If the car is running normally, it is not collapsed. Just to see what would happen, I disconected the hose, and the car started right up. Of course, it ran like crap, but I was able to warm things up enough that then upon reconnecting the intercooler hose the car started up fine and ran fine.
2. One code, 435, if my book is correct that is a slow responding oxygen sensor.
Thanks for the help.
Richard
krisb410
Sep 29, 2012 11:21 AM
chewtoy
Jan 27, 2010 01:53 PM
ANG_S70GLT
Dec 2, 2009 02:20 AM
01silverT5
Jun 20, 2007 01:43 PM
zysoclaplem
Jul 22, 2005 07:58 PM
