Headlamp bulbs for 850 T5
Not a biggie but my headlamp bulb has burned out...its an easy replacement...can someone pls tell me the type of bulb it is? I kinda remember its either an H7 or an H9...TIA..Just tried to add a Sig. pic...
Hopefully this helps.
http://www.sylvania.com/ConsumerProd...RG-Results.htm
Trying the link again.
OK the link keeps dying.
Here is the info that was there.
1996 VOLVO 850 (Wagon)
Low beam headlamp
9006
9006SU SilverStar Ultra: The brightest and whitest light. Up to 50% brighter, up to 40% more downroad visibility and up to 50% more sideroad visibility.
9006ST Silverstar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
9006EB EcoBright - Your Environmental Choice. Save Energy - Save Money. Up to 25% brighter light. CO2 reduced 9 to 21%. Gas savings $2 to $19.
9006XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
9006CB Cool Blue: The whiter light for style. Up to 25% brighter light and up to 25% more downroad visibility.
High beam headlamp
9005
9005SU SilverStar Ultra: The brightest and whitest light. Up to 50% brighter, up to 40% more downroad visibility and up to 50% more sideroad visibility.
9005ST Silverstar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
9005EB EcoBright - Your Environmental Choice. Save Energy - Save Money. Up to 25% brighter light. CO2 reduced 9 to 21%. Gas savings $2 to $19.
9005XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
9005CB Cool Blue: The whiter light for style. Up to 25% brighter light and up to 25% more downroad visibility.
Parking light
1157A
1157ALL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Front turn signal
1157A
Rear turn signal
1156
1156ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
1156LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Tail light
7225
7225LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Stop light
1156
High mount stop light
1156
Fog/Driving light
H3-55W
License plate
2825
2825LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Back up light
1156
Glove box
17053
Map light
64111
Dome light
64111
Step/Courtesy light
2821
2821LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
2825
Trunk/Cargo area
6411
6411LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Instrument-general
2721
2721LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Check engine indicator
2721
Hi-beam indicator
2721
Seat belt indicator
2721
Brake warning
2721
Automatic transmission indicator
2721
Directional signal indicator
2721
Low beam headlamp
9006
High beam headlamp
9005
Parking light
1157A
Front turn signal
1157A
Rear turn signal
1156
Tail light
7225
Stop light
1156
1156
Fog/Driving light
H3-55W
License plate
2825
Back up light
1156
Glove box
17053
Map light
64111
Dome light
64111
Step/Courtesy light
2821
2825
Trunk/Cargo area
6411
Instrument-general
2721
2721
Hi-beam indicator
2721
Seat belt indicator
2721
Brake warning
2721
2721
2721
Thanks for that...I'm sure i'll be referring back to this in the future. So how can I add a pic of my car at the bottom of my posts like you have?
Thanks... I tried that but perhaps i didnt do it right...will give it another shot.
Thanks...i have Photobucket and I know how to copy and paste the image code but it wont upload...says invalid file
Ok in the sig section copy your direct link from the picture you want to use. Then in the sig area click on the little yellow symbol that looks like it has a mountain. Then paste your link and click ok and see if it works.
The sig box I see has no such icon witha mtn on it. I jjust uploaded an image from my computer and evn made a signature...but i dont see it in my posts...perhaps i need to start a new thread? Oh theres the text part of the sig...
Sorry for not getting back to you sooner...however the sig. box I observed did not look like yours...wonder why?
The link is not working. If you can take a screen shot(Print screen) then open paint and paste it in there and save it. Then upload it to photobucket. Then use the same method to insert the pic in this post as I said to do for your sig.
