-   Volvo 850 (https://volvoforums.com/forum/volvo-850-16/)
-   -   Headlight Problems (https://volvoforums.com/forum/volvo-850-16/headlight-problems-50183/)
Tricky1704 Feb 9, 2011 05:59 PM
Headlight Problems
Just got me a lovely big ole 850 96' and lovin it! Having issues with headlights if anyone can help. Both low beams dissapeared on me one morning, one headlight was cracked so I replaced the whole driver side headlamp unit and the bulbs. I was about to change the bulb on the other side too but that had started working again. Had that feeling of satisfaction of a job well done, until I went to start her up again and the lights didnt come on again, then after a few seconds they did, then they were off again. Full beams still work on both sides......any ideas people?:confused:
ThEnder Feb 10, 2011 10:49 AM
I'm new the 850 too so hopefully someone else can chime in but that sounds a lot like it could be a bad headlight relay.
Its Chey Feb 10, 2011 11:19 AM
Jiggle your key. I had an issue with the headlights working that was fixed by replacing the ignition switch.
Tricky1704 Feb 10, 2011 04:54 PM
Well I have a new headlight switch coming and a new headlight relay so hopefully one of those should work will keep ya posted! Seems to be plenty of these type parts available on ebay so must be a common problem.:)
Tricky1704 Feb 12, 2011 06:28 AM
and the winner is........
...........RELAY
£5 on ebay to keep this baby going!
