heat or (a/c) motor lost power after minute
Hi Tech
i am new in here but been fixing manythings to my 93 850 glt by your threads to others
thank you.. this is my question
my blower was noisy and replaced with working use part the priblem is:
soon i turn the fan switch on or to the max it start strong what i want and then few minutes after it lost the power and i don't get air flown strong enough do you know? what is wrong with that? what part? i suppose to replace to get the speed of the fan stable to the max?
thank you in advance...
philly215[&:]
philly215[&:]
RE: heat or (a/c) motor lost power after minute
http://www.fcpgroton.com/images/9137937.jpg
http://www.fcpgroton.com/volvo850cooling.htm
Those links bring you to a site. One pic is of the resistor and the other link is to parts.
Your resistor might not also look exactly like that one.
But it is to the left of the blower motor.
hi again tech
today i was try to take off the blower's resistor and connect bypass the blower works only high speed that mean my blower is good and i have to replace the resistor right wow! it will cost me 139 bucks... i might try u-pull it part if i am lucky to get the working one
thank you for your help,,,
philly215
philly215
hi tech again
it was my resistor bad Tech soon i got the R replaced it works pretty good
thanks tech for helping
and could you refer me to the " Cruise control " troubleshooting
mine cruise control not work... i was looking for checking cruise control system
thanks in advance
thanks in advance
