-   Volvo 850 (https://volvoforums.com/forum/volvo-850-16/)
-   -   heating cooling codes (https://volvoforums.com/forum/volvo-850-16/heating-cooling-codes-32447/)
CarpeNoctem Jul 17, 2009 03:58 AM
hey guys I had an intermittanly loud blower fan. Now it doesn't blow at all. the ac had been cutting in and out driving lately too which i attributed to the 111 degree heat.
i'm showing codes
411 - Blower fan seized or drawing excessive current
414 - Driver side interior temperature sensor inlet fan seized
418 - No control signal to blower fan power stage
it sounds like the over current from the fan dieing, has blown something. Am I looking at a blown resistor, or the EEC thing?
what is the EEC BTW?
850tony Jul 17, 2009 12:06 PM
sounds like a bad fan motor.
and its an ecc. and it is the control for the climate. (aka the knobs u turn)
Ozark Lee Jul 17, 2009 06:41 PM
When the blower fan bearings go bad and it goes into an over current mode it often takes out the power stage (blower resistor) with it. A new blower and a new power stage will fix that.
The other code is for the fan on the temp sensor fan on the driver's side which is located just above the grab bar on the deriver's side of the car. You can usually clean the lint and crud out of that fan and give it a blast of aerosol lubricant and get it to work again.
...Lee
CarpeNoctem Jul 18, 2009 02:42 AM
OK so what is a power stage? never heard of it. another name for the resistor?
btw i found cheap blowers new $59 rather than 150
http://www.logical-source.com/VOLVO/...850-10473.html
Ozark Lee Jul 18, 2009 09:21 AM
On the ECC it is technically a "power stage", on the MCC it is indeed a resistor pack. They get called a blower resistor for both on most of the parts sites so be careful when ordering and get the proper part - they are not interchangeable.
Since one of your codes was for the temp sensor fan and since you could actually pull codes yours is an ECC.
...Lee
CarpeNoctem Aug 4, 2009 08:57 PM
Well I replaced the blower with the one I linked above (MUCH CHEAPER THAN MOST PLACES). And now the blower just stays on constantly even at key off. I unplugged it for now. I this a normal sign of power stage going out?
CarpeNoctem Aug 11, 2009 08:42 PM
Bump for question?
oh and now with the fan unplugged the controlls do not light up. Do they get power from fan?
CarpeNoctem Aug 19, 2009 04:49 AM
Please
Ozark Lee Aug 19, 2009 06:51 PM
The power stage can go out in two different ways - it can open and the blower won't run at all or it can short out and the fan will never shut off. Even key off will not shut the fan off if the power stage is shorted out.
...Lee
