-   Volvo 850 (https://volvoforums.com/forum/volvo-850-16/)
-   -   Help---- FWD Driveshaft shaft bushing damaged (https://volvoforums.com/forum/volvo-850-16/help-fwd-driveshaft-shaft-bushing-damaged-40558/)
dwhartwell Apr 4, 2010 07:43 PM
Removed the drivers side driveshaft to find that the output shaft bushing that the drive axle inside the transmission rotates against is badly scored as is the driveshaft.
- IS this a part that can be replaced? It appears that using a pilot bushing puller I could
remove it. Has Anybody replaced this bushing?
I assume that it can be replaced? Thanks in advance for any help here. My daughter drove 350 miles to visit for Easter. I found a bad seal leak and in pulling this driveshaft to replace the seal found this damage.
fcpgroton Apr 5, 2010 07:38 PM
Yes, it can be replaced. Just make sure you install the new one flush or it will leak.
dwhartwell Apr 8, 2010 08:24 PM
1 Attachment(s)
Hi,
I'm talking about the steel bushing inside of the seal. It looks like it can be removed/replaced but Volvo has no listing for this part. As for the seal, I purchased one from Volvo and installed it all the way in. Not flush with the outside of this case. Sounds like this is incorrect and I need to replace it... again. At the moment it is not leaking.
Do you have the part number/sell seals? If so, please let me know.
As for the steel bushing, do you have a part number/sell these also?
See attachment that shows photo of the bushing I'm talking about
Thanks, Dave
dwhartwell Apr 22, 2010 08:00 PM
bump... anybody?
