-   Volvo 850 (https://volvoforums.com/forum/volvo-850-16/)
-   -   Help ... power steering problem (https://volvoforums.com/forum/volvo-850-16/help-power-steering-problem-21879/)
Delirious Jul 30, 2008 11:08 PM
very stiff steering, is it the pump or the rack?
how to test it?
KALIN850W Jul 31, 2008 07:36 AM
RE: Help ... power steering problem
first check the fluid..always the first thing..
Dads850 Jul 31, 2008 02:37 PM
Dunno how to test, but on my 93, I had stiff steering for 2ish years, then developed a dead spot. Ended up replacing both the rack and pump.
Psaboic Aug 1, 2008 09:04 AM
Definitely check the fluid level first. Actually I would go ahead and replace the fluid. Draw the old stuff out of the reservoir as much as you can with a turkey baster, refill, see what happens. If it is better, do the "draw out/refill/test 2 or three more times and you should have mostly fresh fluid in it.
Delirious Aug 5, 2008 12:03 PM
1st thing I did was to check fluid level then replaced the power steering pump twice with veried results (used pump from wreckers). Now the question is are the pumps any good or is it the rack?
how to test it?
tech Aug 5, 2008 05:47 PM
If you see fluid moving in the pump then the rack is bad.
Psaboic Aug 6, 2008 08:51 AM
Yep.
KALIN850W Aug 7, 2008 07:37 AM
if u turn and hear a "clunking"noise then its more than liekly the rack..
good luck
Delirious Feb 5, 2009 07:49 PM
In case you are wondering I still have not got this stiff steering issue resolved, too damn cold right now to work on. However I have to get it on the road soon for my kids to drive the car.
As advised above I :
- checked the fluid
- there is no fluid movement in the reservoir
- belt is good
- replaced the steering pump with a junk yard one (hum .... yup I know!)
Before I get replacing another steering pump, should I check anything else?
thanks
Delirious Feb 9, 2009 08:25 PM
Got it!
Well ...it turns out it was a seized up steering knuckle! Lifted the car off the ground and greased it up, seams to have solved the problem.
