Home Improved Air Intake?
Old Feb 15, 2006 | 05:24 PM
Blozend's Avatar
Default Home Improved Air Intake?
currently the 850 intake hose stops within the engine. I've heard someone extended the hose to come out of the engine and stick out of hte lower end of the bumper. he claims it improved his mileage from about 19mpg to 32.5mpg. Would this really work? and does it stress the engine in a weird way, such as mess with the air to fuel mixture ratio?
Old Feb 15, 2006 | 09:01 PM
Default RE: Home Improved Air Intake?
As long as the Mass flow sensor is still mounted then you should be fine.
BUT Be careful how low you go with it. You might pick up water and lock the engine.
Old Feb 15, 2006 | 10:18 PM
S70driver's Avatar
It will have to be submerged in the water to get water lock.
Old Feb 16, 2006 | 12:06 AM
robert213's Avatar
ORIGINAL: S70driver
I have seen pictures of what happens to an engine block when the owner decides to drive thru high-water. Air compresses - Water does not!!!!
It will do more than water-lock the engine. The head can be blown off of the block.
Old Feb 16, 2006 | 12:22 AM
ORIGINAL: S70driver
Seem Damage on a 960 from a big puddle with the stock setup. WASN'T PRETTY!!
Swish
Intake, Headers and Exhaust
22
Apr 10, 2015 02:57 AM
mark2765
Oct 10, 2012 05:31 AM
BILL_MCCASSEY
Dec 2, 2008 10:18 PM
rquinonez32
Sep 30, 2008 02:08 PM
m1964
Sep 30, 2006 04:07 PM
