-   Volvo 850 (https://volvoforums.com/forum/volvo-850-16/)
-   -   How Do I Remove A-Pillar trim? (https://volvoforums.com/forum/volvo-850-16/how-do-i-remove-pillar-trim-25571/)
m1964 Dec 14, 2008 07:37 PM
I am planning to install a Parrot kit into my son's 850- I will need to run the michrophone cablefrom under the dash up the a-pillar to the overhead lights -need to remove a-pillar trim and then overhead lights/plastic panel .
Anyone can help?
thanks a lot
PS
the car is 14 y. old and am afraid to break plastic trim ifremoved wrong way.
tech Dec 14, 2008 08:41 PM
RE: How Do I Remove A-Pillar trim?
It pretty much just pulls off. Easiest way is to pull down the seal first then slide fingers in and pop it off.
m1964 Dec 18, 2008 11:38 PM
Thank you,
tech-
can you tell how to remove overhead console ?
thanks
Adrenalin540 Dec 19, 2008 06:36 AM
Pop off the two light covers with a screwdriver or plastic pry tool. Then you will see 2 small torx bits screws in the light openings 1 in each opening, back out those 2 screws and carefully pull it out. Nothin to it...
tech Dec 19, 2008 08:11 AM
ORIGINAL: Adrenalin540
+1
tjsully Aug 13, 2012 04:52 PM
Tech, I also need to pull off the B pillar covers too, the material is coming off and I'd like to reglue it down. It's making my S80 look pretty bad. Also any advice on what kind of glue to use to glue the headliner like material back on to the pillars?
ibified Aug 13, 2012 07:30 PM
btw: the two screws you have to remove for the overhead console are #10 torx. If you dont already own a set of torx bits and you plan on doing work on your volvo, you need to buy a set.
