-   Volvo 850 (https://volvoforums.com/forum/volvo-850-16/)
-   -   How many gears? (https://volvoforums.com/forum/volvo-850-16/how-many-gears-5759/)
tupapison May 11, 2006 08:07 PM
How many gears?
How many gears does this car have? 5? also, a part of the bumper is almost white because of the sun, and AGAIN the shift knob is all peeled thanks to the sun, what product should i use to restore the bumper? forever bumper black?
tech May 11, 2006 09:17 PM
RE: How many gears?
4 Gears
tupapison May 11, 2006 09:18 PM
RE: How many gears?
oh so it will give me the same issue the volvo 940 gave me or not? that when i was going at 60mph, the car was going at 2,600RPM. >_> or this car will behave differently?
tech May 11, 2006 09:28 PM
RE: How many gears?
The gearing is a little different.
tupapison May 11, 2006 09:30 PM
RE: How many gears?
so it wont do that to me? it will be lower than 2600RPM?
tech May 11, 2006 09:43 PM
RE: How many gears?
Not sure not sure which engine it has and what trans it has.
tupapison May 11, 2006 09:47 PM
RE: How many gears?
It has a 2.3 V5 TURBO its an 1996, and its automatic
tech May 11, 2006 10:51 PM
RE: How many gears?
Yes but there is different transmissions. For Automatics.
tupapison May 11, 2006 11:56 PM
RE: How many gears?
how can i know which one it has?
tech May 11, 2006 11:58 PM
RE: How many gears?
Sticker under Hood.
tupapison May 11, 2006 11:59 PM
RE: How many gears?
a sticker under the hood? it will say a number?
tech May 12, 2006 12:00 AM
RE: How many gears?
It should give you the engine Like 5244t for the engine it should also tell you the Trans Like aw55-50 or something like that.
tupapison May 12, 2006 12:01 AM
RE: How many gears?
ok, what else should i look for in this car? because im going tomorrow and i would like to know what falws to look for or what else to look for for further info
tech May 12, 2006 12:03 AM
RE: How many gears?
Surf the 850 Section and you wil find alot of info on what to look for.
tupapison May 12, 2006 12:10 AM
RE: How many gears?
I was surfing but couldnt really find anything >_> :(
tupapison May 12, 2006 12:12 AM
RE: How many gears?
when should the timing belt be changed?
tech May 12, 2006 01:28 AM
RE: How many gears?
70,000 miles
tupapison May 12, 2006 02:23 AM
RE: How many gears?
well the car has like 78,000, so when i go tomorrow ill ask them if it has been changed
fishbulb95 May 13, 2006 04:18 PM
RE: How many gears?
Of course there's the usual things to look for:
Rust, corrosion..etc
Make sure the A/C works
check for any oil leaks <-- Very important
Yes, definatly ask him about the timing belt.
tupapison May 13, 2006 04:30 PM
RE: How many gears?
1. A/C is not working, they need to change like 4 parts in it for it to work
2. Odometer is not working, its stuck at 79k miles
3. Velocimeter(not sure if this is right) is not working, it wont show at the speed im going
4. I have to paint the engine hood, and the fenders
5. Bumper is WHITE, well is black and white.
