how to remove rear brake rotors
Old Aug 2, 2008 | 08:41 AM
bidou's Avatar
Default how to remove rear brake rotors
Hello
I need to change to rear brake rotors. I can easily remove the brake pads, and the bolts that hold the calipers.
But the calipers are held to hard lines, how should I proceed ?
Also, what should I do with the parking barke ?
Thanks
Old Aug 3, 2008 | 05:14 PM
reg's Avatar
reg
Default RE: how to remove rear brake rotors
undo the brake lines at the caliper and loosen the hand brake a tad and you will be set.
r.
Old Aug 3, 2008 | 08:24 PM
bitter356's Avatar
I would also hit the rotor face with a hammer to break away the rust build up in the parking brake shoe area that accumulates on the inside, don't be gentle. Don't forget the rotor retaining screw/bolt.
adamsrotors
39
Jun 25, 2015 01:01 PM
adamsrotors
49
Jun 25, 2015 12:58 PM
bidou
Aug 1, 2008 09:41 PM
brianliverpool
Jun 24, 2008 08:11 PM
zilinski6605
May 12, 2006 09:11 PM
