insuction on how to remove the head
Old Apr 29, 2006 | 07:56 PM
KINGI5T850's Avatar
Default insuction on how to remove the head
can anyone find insuction to take a head off of a 1996 volvo 850 turbo. and does anyone know about the antitheft system on the radeo.
Old Apr 29, 2006 | 08:03 PM
Default RE: insuction on how to remove the head
Not really sure about the instructions for the Head.
It is fairly easy to get off.
What do you need to know about the Radio security?
Once you disconnect the battery you will have to punch in the code when you hook the battery back up.
If you don't have the code get it from your local Dealer.
Old Apr 30, 2006 | 03:04 PM
robert213's Avatar
Browse thru earlier posts from JimK. Read his details on...
1) The Valve Cover must stay with corresponding head. Cam bearing caps/towers are built into Valve Cover.
2) The Cam Bearing Caps/Towers must stay in original location and stay with corresponding head. Heads without corresponding Bearing Caps/Towers must be rebored.
3) There is no Valve Cover Gasket. A liquid gasket is applied with a paint roller.
4) The head bolts must be removed in a specific order. New head bolts are required and must be installed in a specific order -- reverse order of when they were removed.
5) Machine shop should check head for flatness. New Valve Springs may be needed.
divito
Oct 22, 2011 07:11 PM
PieceKeeper
Dec 17, 2008 06:08 PM
autolampsplus
Sep 27, 2008 01:41 PM
ENDEE666
Nov 8, 2006 08:29 PM
johnnybravo
Engine & Internal
Apr 5, 2006 12:52 AM
