Integrated child seat not folding correctly
Apparently some plastic part has broken and I'm having trouble closing the integrated booster in the back seat. Where can I get instructions on disassembling it to see if I can fix it. There are two metalic wires that apparently fold the seat "wings" but I donĀ“t want to start fiddling with that because something might break and spare parts are a PITA to get here.
Any help is greatly appreciated. Regards |
RE: Integrated child seat not folding correctly
If you are wanting instructions on removing the child seat it is straightforward. If you are actually wanting instructions for taking it apart then that is longer, but can be supplied.
[IMG]local://upfiles/4491/E4B1F0C4CF464D46BFAED3CAF343A7A5.jpg[/IMG] |
Thanks, that's what I needed.
Regards |
I removed the seat and disassembled to mechanism. The seat flap mechanism is held in position by a plastic part that has an alluminumblind rivet. The rivet broke so the tensioners were loose. I replaced the rivet with a perforating metal screw and assembled everything back.
Thanks for your help Bill. |
Originally Posted by billofdurham
(Post 56710)
[img]local://upfiles/4491/E4B1F0C4CF464D46BFAED3CAF343A7A5.jpg[/img] |
