Key in ignition
I cannot get the key out of the ignition after I start the car. The engine starts and I can shut it off, but the key does not come out. 1998 s70 glt.</P> Did anyone have the same issue?</P> |
Key in ignition
In my 1998 S70 the gear shift release button (the button you hold down with your fingers to be able to move the gear shift lever) is sticky, and must bepulled out into the normal position before my ignition key will come out.</P> |
