Knock sensor replacement, while Im in there
While Im in there replacing the knock sensors(new style), I am going to replace the PCV system. Any other recommendations of "while your in there" replacement parts while the intake manifold is off?
TIA Jason |
Honestly, the only thing left would be the starter. I don't think you would want to replace that unless it is really, really, really old.
Besides that, you should be good to go. |
Well that is one thing I forgot to mention. I am going to be pulling the starter to check the teeth of the gear and the the teeth of the flywheel. I am getting a grinding noise when starting. Just wanted to make sure there wasnt anything else in there.
Thanks for the reply. :) |
