leaking steering rack.
hey guys l need your help.my steering rack is leaking from the passenger side.its not leaking really bad but little drops. l want to replace the seals and l want to ask if l have uninstall the steering rack from the car before replacing the seals or l can just replace the seals with the steering rack installed on the car.thank you
Hit the easy button man. Get some tranny conditioner, I hear Valvoline makes some good stuff. It may cure the leak forever from what I hear.
It's usually easier to just replace the rack if a conditioner or stop leak additive doesn't work. I think there is a seal kit available as I've been down this road before but I don't know anyone who has ever torn a rack down to just do those outer seals. In all cases we just replace the rack.
Good time to add a filter to the system to protect the pump from the rack shelling out in the future. |
thanks guys, l will add the tranny conditioner and see what happens.if it doesnt stop the leak l will just replace the rack.thanks
Originally Posted by slimflex2
(Post 318264)
I didn't mean tranny stop leak but powed steering stop leak.
Good time to add a filter to the system to protect the pump from the rack shelling out in the future. Kissafrog
So I replaced my rack a few months ago. It came with an inline filter, but since the original didn't have one, I didn't install it. Are you suggesting that I should add the filter? |
Originally Posted by autoxray
(Post 318313)
So I replaced my rack a few months ago. It came with an inline filter, but since the original didn't have one, I didn't install it. Are you suggesting that I should add the filter? It's especially important to install the filter when you replace the rack as the power steering circuit has debris in it from the old failed rack. |
(Post 318313)
So I replaced my rack a few months ago. It came with an inline filter, but since the original didn't have one, I didn't install it. Are you suggesting that I should add the filter? Yes I am. I would put the filter in. It is cheap insurance to have one in the power steering line. |
| All times are GMT -5. The time now is 04:11 AM. |
