ABS light
Old 07-10-2007, 10:33 AM
nncope's Avatar
Default ABS light
i've got a 1994 850 turbo wagon. i love it to death, but it's proving to cause more and more headaches.
my abs light intermittently comes on. i cannot pass state inspection with it on. i code at 142. i guess that's the brake light switch, but my brake lights are working fine.
the bad news is that when i reset it to take for a reinspection the light magically appears for the inspector. it was off for 2 days when i took it in this morning. it came on during the inspection.
any suggestions?
Old 07-10-2007, 01:00 PM
Eli Delta's Avatar
Default RE: ABS light
Sell it> Just Joking, Search for ABS lights on that model you will find your information.
Hope that helps
Old 07-11-2007, 02:06 AM
JPN's Avatar
JPN
JPN is offline
Greetings from Narita, Japan.
Sorry about the problem, I had it, many others had it too. Some people say it is not so common on '93-'94, but many people seem to have had this problem. The nature of failure seems different between '93 & '94 and later models, but it is most likely cracked soldering inside the module. Most places that repair & upgrade the module don't seem to deal with '93 & '94 models, so you have 2 options:
1. Repair it yourself.
2. Buy a new/rebuilt module.
For option 2, you can eBay or get one from FCP Groton of Connecticut (I never use eBay):
http://www.fcpgroton.com/volvo850brakes.htm
Groton seems to sell only used units at $300 with 1-year warranty.
To repair the module by yourself, you would have to have a basic knowledge on electronics and soldering tools. There is a thread on this forum where I posted an instruction with photos, but I'm not sure where it is now. Do a bit of search; I believe it's within the first 10 pages.
EDIT: Did the homework for you:
https://volvoforums.com/m_58856/tm.htm
I hope this gets you going.
JPN
Old 07-11-2007, 07:03 AM
nncope's Avatar
thanks for the tip. i'll let you know how it turns out.
Old 07-11-2007, 11:17 AM
axelm's Avatar
1-4-2 is Faulty stop switch light. Doesn't seem to be an ABS module problem.
nealeas
03-24-2018 09:59 AM
Scott V
2001-2013 model year V70
02-08-2014 06:46 PM
piv15
11-03-2012 07:56 PM
paulh
01-30-2008 08:22 PM
robohopar
09-27-2007 11:37 AM
Quick Reply: ABS light
