Left Headlight Problem
So, I have a 1994 850 Sportwagon. A couple of weeks ago, my left side headlight went dim as I was driving at night. I didn't have a chance to deal with it till yesterday. Here's what I have discovered.
1) When the headlights are on normal mode, the low beam bulb is dim, like it is when the high beams are on. I know that this isn't the bulb, because I purchased a new H4 9006 bulb, and it does the same thing.
2) When the headlights are in high beam mode, the left side goes out entirely. I know this isn't a problem with the high beam bulb, because I switched it with the one from the right side - which works fine - and the problem remained.
3) When the headlights are on, the high beam indicator on the dash partially illuminates. It didn't do this until the headlight problem started.
4) When I turn the high beams on, the "bulb out" indicator comes on.
Anybody have any suggestions?
RE: Left Headlight Problem
So, here's my suggestions:
See attached diagrams; I've circled possible suspects but before you dig into the detail, check the following items:
1. Poor ground for the left low beam.
2. Dirty connector for the left low beam. Remove the connector and clean; a can of electrical contact cleaner & air duster is helpful.
3. Trace the wire for left low beam as much as you can to see if there's an exposed/frayed section.
If above visual inspections turn out OK, then go after the suspects. From what I see on the diagram, it could be one of the following:
1. Faulty Low/High/Turn signal switch (dirty/loose connections): Inspect & clean.
2. Faulty headlight switch: Inspect, clean & replace if necessary.
3. Faulty Headlight relay in the CEU (Central Electrical Unit = Fuse box in the engine compartment): Inspect, clean & replace if necessary.
Without actually taking a look & testing it by myself, electrical problem is a headache. It may or may not be due to a known common problem. See if you can receive others' replies.
P.S: Is your wagon dual bulb or single for low & high beams?
JPN
Attachment deleted.
JPN
Attachment deleted.
atl_volvo
08-22-2008 08:02 AM
