Where is the rear window washer motor?
Does is slide in or bolt in? Quite hard to tell from the location image.
tia
At about 1:50 it shows how you tip it out at the bottom a little and then push it up to release.
https://www.youtube.com/watch?v=gE6k8Jk1pSk
I went at it solo yesterday and got it all handed.
My mount would not slide up as I tried that so I just opened the two retainers carefully and pulled it out the bottom.. I guess that pump is installed upside down as ours is factory and the hoses are on the bottom and the Molex was on top. Heading out on a 1700 mile trek tomorrow and did not want to break the mount so I left the mount in wagon and worked the pump down and out of the bottom of the mount.
Installed functional donor pump.
Check valve in D Pillar was clogged.
Filter (one way design) at rear was full of the nastiest blue chunks of poo I have ever seen. Flushed, shook and re-flushed that a few times in the sink.
Blew the lines out then replaced the one way valve in the D pillar with a T off the donor top pump. A short hose and a screw inserted into the hose with a tie wrap around it capped off the 3rd fitting of the T. Wrapped that modification in some closed cell foam and put a tie wrap around that to prevent rattles of the screw head.
Finally works like new and l learned the rear washer system from tank to tail.
I went at it right after posting my previous comment so your comment and link are much appreciated for future reference. Merry Christmas!
