manual swap brake light switch
1 Attachment(s)
Hey guys, I'm currently in the middle of doing a manual swap on my car and I ran into a little problem, the automatic brake pedal assembly has a square hole (blue arrow) where the brake light switch (green circle) fits into but the manual pedal assembly has a circle instead of a square (red arrow).. I believe that the manual assembly came with a round brake light switch (below red arrow) but the plug is completely different than the square switch from the auto.. The auto's switch has 4 connectors and two on the manual switch.. Do I need to splice some wires, buy a new brake light switch etc? Thanks in advance! :)
Attachment 16117 |
I cannibalized mine and moved the clutch pedal over to the Auto frame.
Or you can get your file out and open up that hole. Be SUPER careful with those switches, its very easy to break. |
Originally Posted by boxpin
(Post 392289)
