-   Volvo 850 (https://volvoforums.com/forum/volvo-850-16/)
-   -   max power?? (https://volvoforums.com/forum/volvo-850-16/max-power-9847/)
tazz Feb 3, 2007 11:21 PM
max power??
would anyone know what the max hp and ft-lbs the volvo 850 could take for the engine and/or the tranny?? i'm lookin to make my car faster but not sure what the safe range is..
info2x Feb 4, 2007 02:12 AM
RE: max power??
Go to Volvospeed's forums they can help you a lot better than most of us here.
[align=left]Volvospeed
[/align][align=left] [/align]
tazz Feb 4, 2007 02:31 AM
RE: max power??
i appreciate it, thanks..
info2x Feb 4, 2007 02:41 AM
RE: max power??
Not a problem in the least.
tech Feb 4, 2007 05:38 PM
RE: max power??
300 Is the Max the block can hold.
Not sure about the torque though.
tazz Feb 5, 2007 11:59 PM
RE: max power??
thanks tech.. thats pretty much what i wanted to know.. now, not that i'm doubting you, but where did you get your info.. cuz it might help me with other stuff too.. and thanks again..
tech Feb 6, 2007 12:08 AM
RE: max power??
I have seen it in here many times and been told.
Also I think there is articles on IPD's web site stating it as well.
tazz Feb 6, 2007 12:40 PM
RE: max power??
thnaks man.. i really appreciate it..
S70driver Feb 6, 2007 03:13 PM
RE: max power??
300 Hp is about what the stock engine and tranny can hold.
If you go higher your going to want to beef that tranny up and also replace the internals of the engine with stronger better goodies.
tazz Feb 7, 2007 03:32 AM
RE: max power??
thanks guys.. would you happen to know if the t5r engine would be a direct swap with the n/a motor?? meaning the motor mounts and n/a tranny would be a direct match, or would i have to switch a couple of things??
JimKW Feb 7, 2007 08:39 AM
RE: max power??
Others have asked thus question and the answer I have heard most often is sell the NA car and buy a turbo. It will be much cheaper in the long run.
S70driver Feb 7, 2007 11:49 AM
RE: max power??
ORIGINAL: tazz
I believe it will fit fine.
This is a much better idea then turboing your NA. Which is exspensive and time consuming.
B1mmer Feb 7, 2007 03:46 PM
RE: max power??
Is it correct to assume that 300 hp is wheel horsepower and not at the crank? - AB
tech Feb 7, 2007 09:26 PM
RE: max power??
The transmission and engine mounts are all the same for mounting.
BUT be warned the trans. will blow fast on a turbo engine.
RedTurbo850 Feb 7, 2007 09:55 PM
RE: max power??
ORIGINAL: JimKW
Yeah, typically for all cars, it's better to get a car which is already turboed (if there's the option) instead of swapping.
But I think some people have some type of attachment to their own car and many choose to swap..
JPN Feb 7, 2007 11:50 PM
RE: max power??
I'm with everyone, additionalturbocharging without additional reinforcement or mods can only shorten usable life of the car, as it's over-stressing many components. But some people seem to want to "Driftise" their cars, especially RWD cars.
Well, this is a personal preference after all. On Volvos, stock turbo seems to produce enough punch, unlike some Saabs. But the performance at lower RPMs, especially below 3,000 RPM, seems sluggish on 850s.
Good day,
JPN
RedTurbo850 Feb 8, 2007 12:39 AM
RE: max power??
ORIGINAL: JPN
Good day,
JPN
Volvo's (850's) have some massive turbo lag.
However, it's nice because you can save on gas a little bit..
