my right turn signal wont turn off
1996 850 turbo
here's the deal. Alll three are on. they dont flash, just solid. the other side(left) works like heaven. I swapped out the hazard light/ flasher in the dash. I have to unplug the negative on the batery to get them to turn off. unplugged the hazard light, still on unplugged the turn signal switch, still on? is there another relay or flasher, please help. the fuse is thirteen and when pulled they go out. i am stumped? |
Check all of the bulbs for a double contact crush joint. Common on the 960's.
https://volvoforums.com/forum/member...b-s90-2176.jpg |
all new bulbs still on
all new bulbs, they are still on
someone help i want to cruise around and be able to turn right
I also have this same problem! Did you figure out the issue ? |
