New noise
Old 03-16-2018, 08:25 PM
Phil 850's Avatar
Default New noise
My car suddenly started making an noise in the dashboard that sounds like a dry speedometer cable or stripped gears in a odometer. Is the speedometer mechanical? What about the odometer?
Old 03-17-2018, 10:41 PM
firebirdparts's Avatar
It's electronic, but as you can see, there is a stepper motor in there running a mechanical odometer. There's no speedo cable.
Old 03-18-2018, 03:38 PM
odometer gears regularly fail. you can find the replacement gears on eBay. only special tool required is a #8 torx bit screwdriver to open up the gauge cluster. Also a good time to replace any burn out dash bulbs...
Old 03-18-2018, 10:32 PM
Phil 850's Avatar
I looked on youtube and the replacement of the gears looks pretty straight forward. I checked IPD and the gears are really cheap.
Old 03-21-2018, 08:28 PM
Phil 850's Avatar
Well the source of the sound finally let it's self known. I was driving today and it was making the noise then suddenly made a bang then was a little quieter. When I parked and got out about half the rubber strip at the top of the windshield had pealed back from one end and was blowing in the wind. Now I need to see if it can be re attached or if the entire windshield needs to be reset.
Old 03-22-2018, 05:00 PM
How funny! My 98 S70 did that, and it sounded like the noise was coming right out of the top of the dash. I saw it in a parking lot, after 3 or 4 days of it being really loud, and then figured out what it was.
Old 03-22-2018, 11:40 PM
Phil 850's Avatar
This was the same thing, loud and sounded like gears in the dashboard. How did you fix it? Did you have to reset the windshield or were ?you able to reattach the trim?
Old 03-27-2018, 01:32 AM
No, I just thew it away. The windshield is fine for now.
ltdakheel
08-03-2016 02:13 PM
Heather202
04-25-2016 08:54 PM
chimmychong
04-02-2008 08:39 AM
ludeless
08-28-2007 07:14 PM
twofourdee
11-28-2005 02:48 PM
Quick Reply: New noise
