no air through vents, blower motor failure?
i have a 93 glt, and today while driving to work, i noticed that i did not have any air coming through the vents, on any speed, and setting. i know that something used to make a squeaking sound before this happened, but now that no air is coming out, there is no squeaking.
would this be the blower motor? |
RE: no air through vents, blower motor failure?
bearing probably went out in the blower, my guess would be the blower too
maybe a relay or the risistor, but i would think it's the blower with the squeaking |
so would replacing my blower motor be my best bet? and how would i go about doing so?
If you want to check the blower motor, you need to remove the glove box and the lower passenger knee bolster/trim to access it. The blower motor is attached to the firewall with three or four torx head screws. Not hard, should take about 30 minutes
assuming you had 4 fan speeds before it stopped working, It is probably the fan.
If you had speeds, 1, 2 and 3, but not 4, it's could be that the resistor went out (also a 30 minute fix once you get the part). That would fix fan speeds 1-3, fixing the 4th speed is either the fuse, or the relay (behind the glove box, a $10 dollar plus about 15 minute fix. If you lost all 4 speeds at once, probably the fan... |
i lost all four speeds at once, all four worked before just fine, and i noticed today i can hear my blower motor like making kind of a knocking sound when i try and turn it on, so im pretty sure thats it
Groton:
http://www.fcpgroton.com/category-ex...36/by_year/43/ eEuro: http://www.eeuroparts.com/Main/Home.aspx May your blower motor rest in peace:(. JPN [IMG]local://upfiles/6892/FD70140BA5024DC68B48525665B4376C.jpg[/IMG] [IMG]local://upfiles/6892/5C55C2C145794BF38CF36F2FB08498BD.jpg[/IMG] |
