No Climate Control/Cruise Control???
There does not seem to be any power to the Climate Control Panel. Nothing lights up, no buttons work, no blower, and also no cruise control. I did not see any blown fuses.
Any thoughts?? |
RE: No Climate Control/Cruise Control???
Also when I check for fault codes. I put the lead in #1 hole of module B. The LED lights and won't go out. So I can't get the error codes.
Has someone had the Dash out lately?
Not that I know of. I had the radio out today but did not disconnect it and I also had the ECC unit out to make sure the connectors were all on, and they were. I also did nopt disconnect the ECC Unit.
This problem started a couple of months ago, but was not the primary issue. Starting the car took first priority. Now it is on to the other problems. ECC, Cruise Control and Flashing Arrow. |
Under the dash in the drivers side. Remove the lower dash panel. Look for either a red plug about 4 inches long or so. Or a yellow one with a Purple pull tab and inspect the wiring there. That is the Main dash feed plug.
| All times are GMT -5. The time now is 10:52 PM. |
