No spark from Ignition coil dam it!
#45
#46
I just found out that the threaded slots where the cam cover bolts go are wider than the bolt itself. Over the years the owner might have taken it to grease monkey Pete who might have over tightened them or what have you. I have 4 5/16th bolts replacing the originals. I have one more to tap and insert the slightly bigger bolt. The oil was oozing from the bolt hole even though the bolt was still inside. I could put silicone around the bolt also.
Kim Gregory
02-20-2013 08:02 AM
