jmana |
07-08-2013 04:19 PM |
Not Good - Weird Electrical Problem
I've got a 94 850 wagon (non turbo) that has 164,000 miles on it. It's had a short somewhere from the day I've bought it and if I either don't drive it every few days, or disconnect the battery, the battery will die. No biggie, but now there's another bigger problem that's popped up and not sure if it's related to the battery draining issue or not. What's going on is the shifter will get stuck in park, and I'll have to use the button to get it out, but then the speedometer, odometer, and occasionally the turn signals won't work! And when it does this the ABS light is on. It did this once a couple months ago, then again a week ago. Both times I shut it off, restarted, and all was fine. Today the gremlin is back and won't go away. Not sure what it is or what to do about it, any ideas??
