Odometer, dashboard lights, and odd noises.
#21
RE: Odometer, dashboard lights, and odd noises.
Hey Quick Brick
You should also check for loose/worn suspension parts and a bad alignment. A bad alignment would pull under braking as would worn parts.
Glad you got the bulbs. I was happy to see my trip computer at night and also my gas gauge.
Cheers
Cheers
#22
Hey hey Autoxray,
I will pick upa caliper on Friday and, with good weather, jack and stand The Anvil and check the front end all over well. But I am fairly certainthat it is the the dr/s caliper that needs to go.
The shudder, during braking is definatly due to warped rotors.
And while I have the car up I am going to take care of the lights and pullout the drivers seat to really give the cara cleaning. Which reminds me, time for a tire rotation.
Check this out. I know that the A/C has been an issue for both of us and I have been looking and came across a link, or two,for you to check out. If you check out the larger view of the parts you will find that the part you are having trouble with (listed as #33)is there as well as a very excellentexploded viewof the entire system.
http://www.eeuroparts.com/Main/PartsResults.aspx
http://www.eeuroparts.com/Main/Diagr...635395d54f.gif
Post a pic of your lit dash and make me jealous. WhyyoulittleIotta (LOL)
Man, its going to be a busy weekend
[sm=icon_cheers.gif]
#23
#24
Hello Autoxray,
Sorry about that [].
For some reason I didnt put that in there so here you go.
http://www.eeuroparts.com/Main/Home.aspx?home=true
Everything I see I want.
quarterdimenickel
07-16-2008 07:52 AM
acorales
03-26-2008 09:46 AM
