Volvo 850 A/C question
RE: Volvo 850 A/C question
Hey now,
It is not recommended to mix R12 and R134.
They are completly different and mixing the two will cost you not only in the efficiency but in reliability.
Everything from poor cooling to compressor damage/failure.
Again, NOT RECOMMENDED.
[sm=icon_cheers.gif]
I have asked the question incorrectly.I used redTek 12a to replace/fill up my R12 and or R134 AC system
Please also have a look here, http://www.redtek.com/win_12a_refintro.html Sorry about that! I got the names mixed up!
ORIGINAL: bbrian017
I believe that you'd be better off not adding redtek if your system is not already running on it. I converted my system to Duracool a year and a half ago, and I had the system evacuated before changing over, just to be sure of any potential noncompatibility issues. And I'm quite pleased with the results. Did it because of a slow leak.
Hey now,
I checked into the Redtek a little further and found this.
http://www.redtek.com/win_12a_chargeinstall.html
Before replacing anything did you follow the directions?[sm=smiley36.gif]
