Oil recommendations
What oil do you recommend for 850 turbo with 120,000
Synthetic would really be your best bet, not sure what viscosity these engines like.
this is not a recommendation but this is what i have been using and its fine for my C70 1998
I use Mobil 1 Fully Synthetic 5W-50 |
My V70 T-5 is currently running 15W40 Synthetic.
I run Castrol Synthetic 5w30 and add a oil additive called MOA by BG.
Originally Posted by Somthngfrce
(Post 152333)
won't the synthetic expose the little leaks
Originally Posted by dlaxdal
(Post 152423)
I think as long as your car is not leaking anything really bad, you will have no problems with it. |
I used Valvoline 10W30 Synthetic Blend for high mileage cars and change it every 3,000-4,000 miles. The closer to 3,000 the better.
Originally Posted by mcleantmw
(Post 152360)
On all our Volvos I used Mobil 1 10-30W.........but for our 2001 V70 with 115,000 miles, I've just switch to Mobil 1 10-30W High Mileage version which has some additives for older vehicles that help to reduce engine wear, protect seals, etc. You can get the details from the Mobil 1 Website.
Originally Posted by cj351stang
(Post 152680)
Just a suggestion; Be careful with the high mileage oils in turbo engines. They cling longer and therefore may burn slightly in your hot turbo oil lines and cause a blockage. I burnt up a turbo on my supra this way....
| All times are GMT -5. The time now is 09:13 AM. |
